| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
I have an ISO program from my retailer. It contains macros for engraving part names, numbers, ect. I don't know how to go about tying them together to make a word. For instance, do I copy the particular macros I need into another program using only the ones I need? Would I then adjust the macro accordingly(size, orientation, ect)? How do I go about entering the proper information needed into the macro? As you can see I need help. My retailer said he received the macros through Mazak but didn't know how to use them without reading them. Thanks, |
| Unfortunately, it has to be looked at in order to understand how it's used. Odds are, you'll have a main macro call line to establish certain things like the character, size, orientation, depth, location, etc. The remaining programs are likely subs. However, as you retailer stated, without looking at it, we can't tell what it is you need to do to make it work.
__________________ It's just a part..... cutter still goes round and round.... |
| How would you normally tie a macro together? For instance, I won't need every letter in the alphabet to spell the word alphabet. Would a separate program need to be created using only the macros to spell each individual letter along with a few others such as letter size, orientation, ect? |
| I take it you're a bit weak in the macro program department.... It's OK, gotta learn some way.... Just guessing what you have here... It might be that you have one program as a 'sample' of how to execute the macro. Any other programs would likely be the actual cutting code. Maybe that's its split up by letters and numbers as seperate files if you have more then one program. As an example of a macro call (Example ONLY!!! Your macro may not function like this!!) G65P8001X3.650Y-2.654Z-.01C64.E8.H.25 The above would mean: G65 = macro call P8001 = macro program number The rest of it are passing variables. XYZ generally remain as machine position much the same as a standard program. It doesn't have to be but this is the "standard" format. Thre rest of it might mean: C = Angle E = number to engrave "8" H = Character height of engraving. Remember, my example is ONLY AN EXAMPLE! Macros are user/programmer definable. You have to understand what is written in your program so that it functions.
| This software is only $200. http://cncwrite.com/ |
| novice questions.... | Matt McColley | General Metalwork Discussion | 7 | 02-16-2009 10:24 AM |
| A NOVICE WITH SOME QUESTIONS | BUTTS | DIY-CNC Router Table Machines | 0 | 07-23-2008 07:11 AM |
| Any advice for a complete novice please? | CarlWalters | Musical Instrument Design & Construction | 4 | 08-14-2007 11:02 PM |
| Novice with uncooperative Y axis | Shepard | Gecko Drives | 0 | 03-14-2007 06:10 PM |
| Novice to CNC | mattinker | Mechanical Calculations/Engineering Design | 0 | 11-27-2006 01:27 PM |
