Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-05-2009, 02:05 PM
JoBwan's Avatar
JoBwan is on a distinguished road
Alarm #260
Slideway lube malfunction? This is on a Mazak QT-20 with a Mazatrol T-Plus controller. It has a Bijur #TMD-5 lube unit. Can anyone tell me if it's the pressure switch or do I need to rebuild the the unit with a motor and gears.
Any help is greatly appreciated.
Just a good ol' boy, never meanin' no harm.
Joe
Old 11-05-2009, 03:03 PM
underthetire is on a distinguished road
lube pump
Don't know the model number of that unit. Plunger type or gear pump type? If it is a gear pump type cap the output of the pump and watch it cycle or use the manual lube button if it has one. DO NOT RUN THE MACHINE WITH IT CAPPED OFF ! Test the pressure at this point. should be about 180 PSI i think. If it's low, take the pump unit apart and clean it. re-assemble and test pressure, if its still low there should be a regulator screw in it to adjust. If the pressure there is ok, you either have:
1. a broken flex line somewhere
2. The lube manifolds are bad and need to be replaced. They are not closing allowing the pump pressure to bypass through them.
Old 11-09-2009, 05:29 AM
JoBwan's Avatar
I have found the motor is not running with 105 Volts AC supplied to it from the machine. I have ordered a new motor and also a pressure switch. I have replaced many switches in the past and could use one, even for stocking it.
Joe
Old 11-09-2009, 09:32 AM
no voltage
if it is a plunger type then you are on the right track.
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Problem- Alarm 350, not in my alarm list, any ideas? ralph@nes Mazak, Mitsubishi, Mazatrol 4 09-27-2008 01:14 PM
