Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-13-2009, 05:25 PM
EliseoMonteverd's Avatar
EliseoMonteverd is on a distinguished road
CRT color, became black
Hello,
Yesterday I turned on my VQC 15/40 M32 as I do it every day, started to load the system and when went around a fifty percent the monitor was black ... but the hydraulic pump and the leds on the front panel turned on also.
Machine can do home #1 and turn the spindle to 2000 rpm without problems but with the black screen... someone can give me an indication where to start to review?
Thank you.
P.S.: Until this happens, had never spent nothing strange previously, it was suddenly.
Old 10-13-2009, 05:54 PM
Al_The_Man's Avatar
If partially black it could be the vertical scan circuit has developed a problem, if completely black, then the CRT high voltage, or the CRT itself.
Both issues will not affect the actual running of the machine.
Old 10-13-2009, 06:12 PM
Yes, it is completely black....
At the moment I am searching info about CRT, and LCD monitors in some forums..Maybe my crt could be mended by a tv or computer serviceman...
Thank you for your interest.
Last edited by EliseoMonteverd; 10-13-2009 at 06:15 PM. Reason: Spanish, English, translaction..
Old 10-13-2009, 07:50 PM
fuzzyracing1967 is on a distinguished road
I don't know of that machine personaly, but just a few months back had the same kind of thing happen, just got done setting it up and boom, blank screen.It turned out there was a little 1 amp fuse that blew in the controler.
Just a thought
Just push the button,what's the worst that could happen.
How to tell the difference in Black ABS VS Black Delrin? conceptmachinin General Material Machining Solutions 5 10-17-2011 09:43 AM
Need Help!- Black screen gamila Fadal 15 03-25-2009 10:56 AM
Jet Black Machine LLC jetblackaircraf Product Announcements & Manufacturer News 0 12-23-2008 12:41 AM
More monitor black out Kool Parts Haas Mills 2 10-28-2008 09:22 AM
WHO Does Black PVD? mabmojo Metal Finishing and Plating 0 09-25-2008 09:56 AM
