Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-02-2009, 11:55 AM
wizbangdoodle is on a distinguished road
MR-J2 software and cable
I need to do some adjustments on a MR-J2 drive for a rotary table. I found the link to the software here on CNCZone (thank you). I just need the cable that connects the drive to my PC. Does anyone have the specs for this. Mitsubishi wants $86 for what they refer to as an RS-232 cable. I've made several cables and because I am cheap, can't see spending $86 on $4 worth of parts. Thanks for any help.
Old 10-02-2009, 10:11 PM
psychomill is on a distinguished road
You don't necessarily need to connect to the MR-J2 to make any adjustments. If this is a Mazak, the software is loaded on the control already. Just open the application through windows...
It's just a part..... cutter still goes round and round....
Old 10-03-2009, 01:15 PM
Rokkin is on a distinguished road
It may be an MPLUS control which doesn't have onboard s/w.
Old 10-04-2009, 11:45 AM
Yep... M Plus doesn't have use a Windows OS...
... it also doesn't use a MR-J2....
The cable to connect to a MR-J2 is a DB9 to MDR (20 pin I think)... but AFAIK, MR-J2 didn't start usage until Fusion. So the set up software is loaded on the control....
Old 10-04-2009, 08:49 PM
Sorry to say that this, but this machine has 2 MR-J2 drives in it, 1 for the rotary table and 1 for the ATC. It has an M Plus control, so they must have come before the Fusion.
Old 10-05-2009, 09:10 AM
onthebumper is on a distinguished road
Yes the M-Plus controls used an MR-J2 drive. What is the exact model of the MR-J2 drive? Does it have a CT at the the end or an A at the end. This will matter when it comes to the software and cable that is used on the drive.
Old 10-05-2009, 09:33 AM
Good to know. I figure there was a transition period in there somewhere depending the models... just hadn't seen it. I have seen Fusion machines that ran the old drives and/or relays. Almost like a Fusion control that got stuffed onto a M Plus machine. Talk about strange to work on.
Old 10-05-2009, 12:52 PM
Yes, very strange to work on.
Onthebumper, it has a CT at the end, MR-J2-40CT and 60CT. One for the table and one for the ATC. What difference could there be?
Old 10-05-2009, 01:10 PM
The CT drives are made specifically for Mitsubishi CNC controls and the A drives are a general purpose servo for industrial applications. Both are similar but different
These two manuals should explain most of your questions.
http://www.meau.com/functions/dms/ge...00000464300000
http://www.meau.com/functions/dms/ge...00000675100000
Old 10-05-2009, 02:16 PM
Thanks onthebumper, exactly what I was looking for.
cable drive dertsap Linear and Rotary Motion 39 09-23-2010 10:35 PM
without using a cable jwest DIY-CNC Router Table Machines 7 11-26-2008 01:46 AM
USB Cable HillBilly Granite Devices 3 05-18-2008 02:39 PM
Diy Cable Guide Regnar DIY-CNC Router Table Machines 14 07-29-2007 03:58 PM
cable lgalla Stepper Motors and Drives 7 02-10-2007 09:55 AM
