Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-29-2009, 10:09 PM
beno is on a distinguished road
mazatrol t1 errors
i have a error on a mazatrol t1 . 82 ille. tool no.
i am very new to using mazatrol and cant get the machine past this alarm signal. can anyone tell me the meaning of this alarm signal.
Old 09-29-2009, 10:17 PM
Al_The_Man's Avatar
The full description of 82 is Process data entry error - Inapplicable tool Number instruction (No tool assigned).
Old 09-29-2009, 10:30 PM
does the tool number consist of only the turret position? i can see a screen that has the tool description, can there be a problem here which will indicate the same error?
Old 09-29-2009, 11:11 PM
i have another error message, 101 missing condition.
Old 09-30-2009, 05:14 PM
MTSS Service is on a distinguished road
Tool Data
Hi There;
Have you register your tools on the tool data file location of the T1 mazatrol.
Chance are you are missing some imporatant info for the tools on your turret. Go to your program location and select tool data.
You can also get to the tool data by selecting the menu keys. Make sure you put each tool in correctly.
If you have the operator manual it can help you in this area. Also the alarm manual has the alarms listed and can tell you exactly what is going on.
Hope this helps you out some.
MTSS
Old 10-01-2009, 12:11 AM
thanks for the help. i have moved forward with some of te machines controls but witout a manual i'm a bit in the dark. is there any manuals avaliable on the net? or can i get an example of a simple program from some were?
Old 10-01-2009, 07:24 PM
Mazak T1 Manuals
Hi Again;
I have to look around my office area, but I think I may have a General Information manual for programming and tool setup.
Not certain on the On Line Manual Sources .
Will e-mail you if I find that manual.
MTSS
Old 10-05-2009, 05:21 PM
T1 Mazatrol
Hello There;
Not sure how far you have got on your control , but I did find a manual that I could send simple programs and other info to you.
Give me a good e-mail address so I can send you some info that will help you understand the T1 better.
MTSS
mtsslrg@peoplepc.com
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
Need Help!- Getting 2 Errors.... Someone Please!! DesKitchens Commercial CNC Wood Routers 0 09-14-2009 08:30 AM
x axis errors...help stanglou General Metal Working Machines 0 04-27-2007 12:46 AM
Help:possible M/c tool errors bala_51083 General CNC (Mill and Lathe) Control Software (NC) 0 04-14-2007 03:38 PM
