| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
We have a Mazak Mill Nexus 510C with a 640m control when you take a tool out of the spindle you have to go to mdi and command a M19 the go to manual mode and turn the clamp unclamp key to get the tool out the problem we are haveing is some times when you put the tool back in the spindle and turn the key back the spindle will rotate like it is doing the M19 again at this point you are holding the tool in your hand has anyone seen this before on this machine? |
There is absolutely no way that is acceptable!!!!! I would contact Mazak and tell them what that thing is doing. From a liability standpoint they should be real interested in solving and fixing that problem on a recent machine model even if it is a little out of warranty. If you don't orient(M19) and use the Tool Unclamp OK soft key does the spindle take off when you reclamp the tool? Maybe a work around until the orient problem is fixed. Lee |
| I'd check this out to see if it still moves.....
__________________ It's just a part..... cutter still goes round and round.... |
| Newbie- Unexpected Lathe; much confision! | serriadh | Mini Lathe | 1 | 06-16-2009 09:29 AM |
| Movement in spindle | Hirudin | Taig Mills & Lathes | 7 | 03-19-2009 10:19 AM |
| Need Help!- Series 1 Spindle movement problems | bartL | Bridgeport and Hardinge Mills | 45 | 03-03-2008 12:18 AM |
| X Axis movement when spindle is on | FFAMN | Servo Motors and Drives | 3 | 12-24-2007 09:27 AM |
| stationary spindle with X,Y,Z movement | KBW | Haas Mills | 2 | 02-10-2004 07:42 AM |
