Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-22-2009, 06:36 AM
PaulZad is on a distinguished road
Alarm Code 261 Arm Retrac. Malf.
Hi Folks,
this is my first post. I have a new person running my Mazak and he used a set screw that was too long for the tool holder to hold his 1 inch mill. The protruding screw evidently made the tool sit in the Toll Changer Arm slanted and it got stuck. I got the tool out but the arm is now not moving. I get an alarm code 261 ATC ARM RETRACT SENSOR MALF. Can anyone help????
Thanks in advance!!!
Paul
Old 09-22-2009, 07:51 AM
TiggerII is on a distinguished road
What Control? What machine?
Old 09-22-2009, 08:13 AM
MTSS Service is on a distinguished road
Need To Give Us More Details Of Machine Type and control
Hi There;
Depending on machine type and control there are procedures that you can use to correct this problem.
However , you need to post what type of Machine Model you have and which control you have on it as well.
Larry (MTSS)
Old 09-23-2009, 06:09 AM
Thumbs up
Sorry for not giving all the important info on the machine, I'm new at these kinds of forums.
Our Mazak is a V-414/22 and it has a Mazatrol Plus controller.
Man it would be great if there was some way to re-home/reset that ATC arm.
Thanks again in advance!!!!
Paul
Old 09-23-2009, 10:01 AM
ATC Procedures
Paul;
Contact me via e-mail @ mtsslrg@peoplepc.com. The procedure is way to long to be posted in here.
I'm certain I may be able to help you out on your problems.
Larry (MTSS)
Need Help!- Alarm code 123 VF-3 Nova Haas Mills 12 06-16-2010 02:48 PM
Need Help!- Alarm Code 79 and 86 RC-CNC Fanuc 18 02-23-2009 09:37 AM
QT-15 NMI stop and Spindle Controller Malf Talisman Mazak, Mitsubishi, Mazatrol 3 07-10-2008 10:37 AM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
m32 alarm 27 magnetic position detect malf. barebonzchop Mazak, Mitsubishi, Mazatrol 2 11-02-2006 09:48 PM
