Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-11-2009, 02:52 PM
sve0019 is on a distinguished road
Drip feed on/off
Hey
My Mazak Masatrol cam M2 i one day desided to tray found
out if it haved DripFed by Pressing Auto button and F2 at the same
time.I did have becuse in middle down i got EIA/ISO in red,and in top right
four XXXX like these.
However its problem i dont know how to switch off the drip feed now.
Please help somebody.
Sve0019.
Old 09-11-2009, 03:43 PM
*Registered*
cncjunky is on a distinguished road
Originally Posted by sve0019 View Post
Hey
Sve0019.
Well I know on my controller the option to drip feed is a 1 time deal, it does'nt stay on, when you load your file, then you click F2 to drip feed, then it takes off on it's own. Or if the file is small enough you can just click F1 to pick what you want to open and then F4 to load . Then go through your program and choose "run program". I don't know for sure with your controller because I don't own one, but I wouldn't be suprised if it's the same. Hope this helps
Old 09-12-2009, 05:09 AM
More drip feed
Dear freind.
Iv have write a new program complitly masatrol M2
and i want to test it in grafic but screen dont show any at
all probly becuse controller stands in recive mode for EIA/ISO
as i told before.I need to take away the state I did before by pressing
Auto and F2,means thats it dont show on screen eia/iso and XXXX.
As I told before.
With Regards
Sve0019.
Once more I want to run an masatrol prog NOT EIA/ISO.
I must get rid off drip feed state that my machine is in.
Restart it wont work,it remember to well.
Old 09-14-2009, 11:14 AM
*Registered*
I can look through my manual and see what it says for my controller, but my controller is a centroid so I can't really say if I might find the answer or not. I know alot of these controllers have alot of simialarities in them. If you have a manual for your controller I'd give it a good study and you'll probably find your answer. If not then you really should call Mazak and see what they tell you, most likely they will be able to help you and for free. I had a problem with a setting " I forget exactly what it was right now" and centroid helped me for free, most these places will help you with stuff like that for free.
Need Help!- drip feed kirby Fanuc 29 11-28-2009 08:04 PM
Need Help!- Drip feed, DNC? Greg_B Mastercam 7 05-19-2009 11:31 PM
Need Help!- Drip Feed kirby Fanuc 23 10-20-2008 09:21 AM
BMC-20 w/Max II drip feed...... GPena HURCO 6 10-31-2007 12:37 PM
Drip Feed camtd Surfcam 0 07-31-2006 06:09 PM
