| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| Hallo everyone I have a problem with a yang VMC EAGLE 1000 When i power up the machine in the morning it works about one-two hours, then this alarm appears on the screen S01 servo alarm:PR 0010 S emergency Spindle If i power off-on and start to work again , after 5min the same message appears. But if i power off the machine for more time ,then the machine can work more... it is seems that maybe the drive is defective? Thank you in advance |
| According to my manual this alarm indicates a low bus voltage condition in the drive. I would first check the fuses going into the spindle drive and verify you have the correct voltage being supplied to it. If these both check OK there might be a bad rectifier in the DC bus circuit. Regards, Scott |
| try www.meau.com I don't remember what manuals they have for the M50. If you can't find any then download the alarm & parameter manual for 60 series instead. The information is close enough to still be quite useful. |
| Downloading the mauals will be tricky from your location (Greece). Meau.com redirects European customers to melfans website where there are no downloads to help you. You need to use a proxy or disable some scripting options from the browser. You can check my solution at Practical Machinist: http://www.cnczone.com/vb...d.php?t=119989 |
| Hi, I have a simmilar problem with an XYZ 850 Vulcan with an Meldas M50. I am geting alarm code: S01 servo alarm:PR 0024 S emergency Spindle I have managed to get download the manual from www.gcodex.com but the PR 0024 S code is not mentioned! Has anyone else had this or can anyone advise where I can go to get some advice? I have gone to our XYZ manufacturer and they referred me to their "old" mitsubishi man but he cant seem to help?? Thanks Mike |
| Check for ground fault, motor or cables etc. Oh beaten to it. Al.
#12
Hi, Alarm 10 is the Under Voltage (Incoming Supply) alarm. It can also happen due to the malfunction of Opto-Isolator in the drive, which sense the voltage supply & give feedback to processor. Check the voltage supply to the at the drive with alarm (at L1, L2,L3) if it is 200V, then the problem could be Opto, will need to replace the drive from Mitsubishi.Is it MDS-B-SVJ2 series or MDS-A-SVJ series? Is this alarm for one or all of the axes drives? Regards, Girish |
| Meldas 50M Alarm | Lawrence B | Mazak, Mitsubishi, Mazatrol | 6 | 10-16-2009 02:35 PM |
| Problem- meldas 65 sm. alarm s03 nr 5c s | udrııl79 | Mazak, Mitsubishi, Mazatrol | 3 | 07-28-2009 10:08 AM |
| Alarm 511 Meldas Mo | LnL | General Metal Working Machines | 0 | 07-11-2007 03:32 PM |
| Alarm 511 Meldas Mo | LnL | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 07-11-2007 10:02 AM |
| Alarm 511 Meldas Mo | LnL | General Metal Working Machines | 0 | 07-11-2007 09:40 AM |
