| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Im looking at purchasing a 1988 Mazatrol Cam T-2 CNC Control, 8 Station Turret, Tailstock, 8" Power Chuck There is an alarm code showing which is defined as the following: # 9, “No feedback signal is returned from the X-Axial resolver in response to a NC unit command Is this a bad alarm, or something simple . Also can one get parts for these early machines??? Thanks Chips |
| This seems like a relatively simple alarm and pretty straight forward. Could be the following: 1) Bad resolver 2) Bad feedback cable 3) Bad feedback card (FX06). Maybe just an adjustment on this card. F/B signal could be present, but low. I don't suspect the servo drive since feedback goes directly to the CNC. |
| You can get them from Mitsubishi in Chicago. Although the X & Z are different resolutions, you can swap them over just to check, or if you identify the feedback cables on the processor board, you can swap them to see if the fault follows the plug. Make sure you get the right part number off the unit, the Mazak parts list sometimes shows the wrong resolution part. Al.
| need help mazak alarm 31 | jaimeeduardo | Mazak, Mitsubishi, Mazatrol | 7 | 03-31-2009 09:33 AM |
| Problem- Mazak SQT 18 205 alarm | twistedturner | General Metal Working Machines | 0 | 03-08-2009 04:06 PM |
| Mazak H-500 Alarm | newguy81 | Mazak, Mitsubishi, Mazatrol | 4 | 09-27-2007 09:33 PM |
| Mazak FAN alarm | leito1489 | Mazak, Mitsubishi, Mazatrol | 2 | 09-08-2007 08:22 PM |
| Mazak L Alarm | SFA | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 05-26-2005 12:52 AM |
