Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-02-2009, 10:49 PM
gandrtooling is on a distinguished road
how do I slow the rapid
HELP PLEASE
How do I slow the rapid down on my Mazak Slant turn 30,I can't find which parameter to change.
Old 09-03-2009, 07:58 AM
onthebumper is on a distinguished road
It would help if you can tell us the control model.
Old 09-03-2009, 02:35 PM
MrMazak is on a distinguished road
Probably a T-1 which has a "Rapid Reduce" button that slows the rapid by 50%. T-32 would have a five step "Rapid Reduce" That slows it down by 50%,
75% and down to 5% (steps have parameter settings that can change the percentages) T-PLUS has the same as T32. Someone could change the parameters to 100% to lock out rapid reduction. (some sneaky operators will reduce rapids to make the cycle longer)
Old 09-03-2009, 06:49 PM
my contol mdel is fanuc 6t
Old 09-03-2009, 06:57 PM
Al_The_Man's Avatar
Rapid traverse rate is 092 for the X and 093 for the Z.
Units in mm/min if mm output or 0.1"/min inch output.
Old 09-07-2009, 10:33 PM
it worked great thanks for your help
Regards Tony
Problem- rapid c axis movement slow chunkymonkey CNC Swiss Screw Machines 4 02-21-2009 02:02 AM
Why so slow? happytriger2000 Mach Mill 0 12-06-2006 05:36 AM
O mate M slow rapid rate Phase II diemaker Fanuc 0 10-18-2006 04:08 AM
O mate M slow rapid rate diemaker Fanuc 6 10-09-2006 02:14 PM
slow tm-1 pit202 Haas Mills 23 04-18-2006 02:14 AM
