Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-27-2009, 10:48 AM
elmmachine is on a distinguished road
m-2 display problem
when i power up the machine the crt only shows xyz numbers and the numbers where the go on.no letters at all on the screen.where the load meter is shows load but no words.also the display button and the menu buttons do not work.this is a mazak v7.5 machining center. thanks mark.
Anilam Series GX-M Display Problem ZDR-NGinEar General CNC (Mill and Lathe) Control Software (NC) 0 08-08-2008 08:04 PM
Table display problem SScnc Mach Mill 2 08-04-2008 12:44 PM
RPM display fatal-exception Mach Mill 0 11-24-2007 03:02 PM
EZTrak DISPLAY dominicmarceau Bridgeport and Hardinge Mills 8 05-30-2007 10:18 AM
Problem with OM Monitor/Display darrylh Fanuc 0 01-13-2006 06:04 PM
