Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-21-2009, 03:18 PM
doglips6 is on a distinguished road
QT200MSY/MATRIX COTROL
OVER TRAVELED ON X AND Y AXIS. OT RELEASE WITH RESET BUTTON DOWN DOES NOT WORK. OT RELEASE WITH MFI OR MF2 BUTTONS DOES NOT WORK.
I THINK I NEED TO RESET OR CHANGE A PARAMETER. THAT WAS CHANGED IN THE PROCESS OF RESETTING CENTERLINE ZERO BUT TECH NOT AVAILABLE AND NOT VERY EXPERIENCED WITH MATRIX CONTROLS ANY-WAY. ANY SUGGESTIONS WOULD BE APPRECIATED.
Old 08-21-2009, 08:29 PM
Rokkin is on a distinguished road
Did you try MF1, MF2 AND RESET?? Pressing all three at the same time should allow you to handle the axis if it's a true overtravel condition and nothing else is wrong.
Old 08-22-2009, 06:31 AM
Leelund is on a distinguished road
If you believe that the tech's parameter change caused the OT problem, why not have him change them back to the original numbers and see if the OT problem goes away? You must isolate the cause before you can fix the problem.
Need Help!- Matrix joedirt Mazak, Mitsubishi, Mazatrol 2 11-25-2010 05:23 PM
Mazatrol Matrix wawankot Mazak, Mitsubishi, Mazatrol 6 04-01-2009 01:16 PM
Matrix controller fpworks Mazak, Mitsubishi, Mazatrol 7 12-11-2008 10:27 AM
Need Help!- VCN Matrix operations1 Want To Buy...Need help! 0 10-02-2008 05:51 AM
Bridgeport EZ Track DX 2 cotrol panel needs help!! mailloux Post Processor Files 3 09-13-2006 07:15 PM
