Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-21-2009, 10:08 AM
bluechipmfgllc is on a distinguished road
mazak nexus 200 lathe - spindle problem - matrix control
This is on a Matrix control
Normally when the machine is in manual mode, you're allowed to click the up and down button, and run the spindle either forward or reverse.
For some reason the spindle start and stop buttons work, but the up and down buttons don't. So I can't get the spindle to run while in manual operation mode. But it all runs fine when in automatic.
Anyone got any thoughts on what the problem could be...could it be a circuit in the back of the machine? It's been like this the last 2 times i've turned on the machine, and it just happened outta nowhere.
Thanks for the help.
Old 08-21-2009, 03:43 PM
doglips6 is on a distinguished road
NOT SURE THIS WILL HELP BUT MATRIX IS REAL PICKY. I WOULD MAKE SURE DOOR IS CLOSED CHUCK IS CLOSED ALL AXIS TO ZERO BAR-FEED LINK OFF C AXIS LINK OFF SPINDLE LINK OFF MAIN OR SPINDLE ONE SELECTED .
AXIS SELECT SWITH TO OFF . PRESS FWD OR REV THEN UP ARROW TO DESIRED RPM .HOPE IT WERKS
Old 08-21-2009, 04:54 PM
fizzissist's Avatar
fizzissist is on a distinguished road
When it's done it to me, it's usually because I forgot to close the chuck.... Spindle on mine won't turn unless you're clamped on the workpiece.
Old 08-24-2009, 10:05 AM
It's just seemed to happen out of no where. We don't have the lock on our door so the machine can run without the door shut.
I'm not sure whats going on with it. We can still run parts, it's just the thing wont spin, without running a part.
Old 08-24-2009, 02:07 PM
CNCBoss is on a distinguished road
Could be that your board switches are bad. We have had a very simular problem, spindle speed increase would work, decrease would not. We had to replace the entire control circuit board to fix.
Old 08-25-2009, 08:47 AM
Thats what I was afraid it would be. We previously lost use of the "input" button, and had to switch the board out.
Old 08-25-2009, 09:58 AM
Don't ya just love the fact you can't change out individual buttons. The overlay begins to get worn and lets coolant and dirt into the board and bingo! You get to order a new board and overlay.
Problem with toolchange in Mazak Quickturn nexus II Legenden Mazak, Mitsubishi, Mazatrol 2 03-31-2009 02:36 PM
HELP MAZAK MATRIX NEXUS grants66 Mazak, Mitsubishi, Mazatrol 1 03-17-2009 08:57 AM
eia restart problem on mazak nexus 640m mill Denis13 Mazak, Mitsubishi, Mazatrol 1 02-04-2008 08:58 AM
Mazak Nexus 250 lathe, with hydrolic pressure issue FanucIssues Mazak, Mitsubishi, Mazatrol 3 05-31-2007 09:02 PM
Mazak quick turn nexus 250ms 640t control sidecar82 Mazak, Mitsubishi, Mazatrol 8 04-04-2007 07:07 PM
