Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-21-2009, 08:47 AM
extanker59's Avatar
extanker59 is on a distinguished road
Ezatrol/Mazak settings
Hi. We have a QTN-100. The control says Mazatol 640T Nexus on the face.
We purchased Ezatrol Pro. and the cable from Ezatrol. I am not conversant in computer communications. We are trying to save and send Mazatrol programs. So far I have recieved part of the test program into the computer but not all of it (the comments are cut off and it looks incomplete). Sending to the CNC has alarmed out every time.
Can someone help with the settings of both Ezatro and the Mazak? There must be a standard set of setting (I hope).
Chris
Old 08-25-2009, 11:09 AM
Captdave is on a distinguished road
Try contacting Erik at Ezatrol he helped me set mine up. I'm not sure about your control, but he had to send another cable end with the correct pin out to get mine working.
Old 08-25-2009, 11:27 AM
extanker59's Avatar
OK, thanks
Old 08-31-2009, 11:48 AM
efem77 is on a distinguished road
help mazak alarm code
Old 09-01-2009, 01:57 PM
golijoef is on a distinguished road
The cable wiring should be the same for all systems.
At the machine side on the 25 pin:
2=white
3=red
7=green
jump 8, 6 and 20
jump 4 and 5
On the computer side 9 pin:
2=red
3=white
7=green
The color is not important just as a ref. so you can see that 2 and 3 are crossed.
The parameters should be strait forward.
Old 09-08-2009, 10:19 AM
Did you get in contact with Eric and get your software working?
Old 09-09-2009, 06:31 AM
extanker59's Avatar
Not yet. Too busy to call. Busy is a "problem" I can live with.
We exchanged emails and I wrote to him, after he asked me to call, but he hasn't written back. Vacation maybe? I need to be free at the same time as the Mazak. Not always possible.
Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings Bfarn Machines running Mach Software 7 12-17-2008 10:45 AM
Settings piedpipertraps DynaTorch 7 10-15-2008 05:30 PM
Need Help!- Mazak QT-10 T2 manuals --acct w/ mazak? CDTINC Mazak, Mitsubishi, Mazatrol 0 06-30-2008 08:42 AM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
dnc settings jamesr Fanuc 1 02-02-2006 02:13 PM
