Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-18-2009, 07:15 PM
gandrtooling is on a distinguished road
Question HELP PLEASE
HELP PLEASE
I have a Mazak cnc that keeps on stoping with a( 410 servo alarm )the value of position deviation amount of the X axis is larger than the value allowed while the machine is stopped.This happens while rapiding in the x axis,does anyone out there have a solution?
Thanks Tony
Old 08-19-2009, 07:52 AM
SORCHEROR is on a distinguished road
maybe a bad encoder or faulty tach,did you try slowing down your rapid to see if it still
does it,i would lean more towards the tach
Old 08-19-2009, 03:47 PM
thanks
ye I changed the G00 at the start of cut to a G01 and it helped.How do you change the rapid speed.I don't have a manual.
Thanks Tony
Old 08-19-2009, 03:51 PM
Al_The_Man's Avatar
It helps to give the machine type and the make of the control.
Mazak fitted primarily Mitsubishi but some Fanuc, the 410 alarm sound like a Fanuc number.
If it is Fanuc, it may help for future question to ask in the Fanuc Forum.
Old 08-21-2009, 07:34 AM
on the control there should be a rapid overide button,try running at 50%,i think your machine is just older and tired,i had one that wont run at full rapid without faulting out
could be any of a number of things ,but if it works at half the rapid might be way to go
