Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-08-2009, 03:23 PM
mbi mbi is offline
mbi is on a distinguished road
Adding an EIA program as a subprogram in Mazatrol
I would like to add a 3d profile into my Mazatrol program.
Here is what i have:
A good Mazatrol program.
A good G code program of the profile.
Both programs will run by themselves. I would like to put them together if possible. What i'm not sure about is the WPC'S and how to get back out of the EIA program into Mazatrol.
Does anyone know how to?
Old 08-10-2009, 05:25 AM
jimiscnc is on a distinguished road
suggestions
go to "other" unit, then "Sub program" unit and fill in the blanks. extra lines are for loading user macro values and can be ignored. these are softkey names and are from memory, so may not be the exact names i used.
wpc values should carry over to eia sub, but that can be controlled by parameter, i'm pretty sure.
Eia sub should have an M99 at the end, and it should loop back to the next unit in the mazatrol.
it can be verified in tool path check.
more or less. from memory
-90% Jimmy
Old 08-11-2009, 04:11 PM
bildoo is on a distinguished road
I use that method daily.
Subing into the EIA program and then using M99 to come back to the Mazatrol program works great. The EIA program will use the WPC that is currently in use by the Mazatrol program (Including using WPC Shift as on a Variaxis). Using any Offset lines will not transfer over into the EIA program. Another issue is tool priorities. The best way I found around this was to use pri numbers 1-100 before the EIA program then I use delayed pri numbers 1-100 after.
Old 08-13-2009, 05:27 PM
Tool priorities are for POWER USERS! Good work. bildoo!
-90% Jimmy
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Mazatrol Sub Program jhersh Mazak, Mitsubishi, Mazatrol 2 12-03-2008 04:09 AM
Adding comments in program for Pro NC quadbob PTC Pro/Manufacture 1 04-27-2007 03:54 AM
Eia subprogram in mazatrol magneto259 Mazak, Mitsubishi, Mazatrol 3 04-10-2007 10:19 AM
Mazatrol subprogram BeanO Mazak, Mitsubishi, Mazatrol 5 11-24-2005 03:12 AM
