Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-30-2009, 07:49 AM
mbpp is on a distinguished road
Problem with live tools
I have a problem with the live tooling on my mazak sqt15ms. I used it 2 weeks ago and it worked fine. But now when I try to spin a live tool in either a programme or manually it struggles to spin. it spins for a few seconds, stops, spins for a few seconds, stops, it continues like this for a while and then stops completely and I get Alarm 239 on the screen which is : " Milling Coupling Sensor Malf."
Has anyone any experience with this ? Do I need to take off the turret and start looking for a sensor ?
Any help would be appreciated.
Old 07-30-2009, 06:46 PM
Leelund is on a distinguished road
Sounds like the driver is not engaging in the driven tool and after two or three tries it alarms out. Hold a block of wood or something against the tooling nut to create drag and see if the coupling drops in and the mill spindle gets up to speed in mdi mode. If it snaps in and you still get the alarm you have a proximity switch problem. If it works, your bearings in the tooling are getting too loose and you'll have to figure a way out to make the tool drag a bit. We put alemite fittings in the tooling and over packed it with grease to create the drag. This was on a 1st version multiplex. They have refined it a lot since those days. We worked with slowing down the speed of the coupling extension by installing a regulator in line to the cylinder so it wouldn't push as hard against the driver thus slip a little and let the driver line up and drop in. The sensors are under the center aluminum center cover and should have led indicators on them when they are made.
Old 08-10-2009, 05:48 AM
Thanks Leelund,
I took off the aluminium cover from the centre of the turret and saw that one of the proximity sensors was not lighting up when the motor shaft extended so I got a new switch and replaced it. All is working now. Thanks for the info it turned out to be an easy fix and I thought it was going to be a nightmare. Thanks a lot.
Mark.
Need Help!- BobCad Live Tools? DIFF OVER BobCad-Cam 4 03-23-2009 10:10 AM
Live tools only or Y-Axis? grweldon General Metalwork Discussion 2 11-19-2008 08:26 AM
Haas Lathe TL-25B with live tools LONERO Haas Mills 3 09-30-2008 05:52 PM
LOCKING LIVE TOOLS littlerobb Okuma 0 09-04-2008 12:30 PM
threading with live center problem jeremyinnys General Metalwork Discussion 4 10-30-2005 08:14 PM
