Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-20-2009, 03:10 PM
dcorrick is on a distinguished road
Need Help Mazak T32-3 Circular Interpolating
We have a T32-3 control on a Mazak lathe with live tooling on the turret. We want to cut a circular hole using the "C"-"Z" axis and the "X" will be the Z depth axis. We are using manual milling program. Does anyone have an example on how this is set up? The program manual shows it, but no example!
Need Help!- Circular Cut mikelohj LinuxCNC (formerly EMC2) 1 06-18-2009 12:19 PM
What do you know about this circular saw??? mailloux WoodWorking 5 10-16-2007 10:34 PM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
mazak 640m circular tornado milling cycle magneto259 Mazak, Mitsubishi, Mazatrol 5 04-20-2007 12:03 PM
Mazak Mill Circular Interpolation problem DublJ Mazak, Mitsubishi, Mazatrol 2 02-13-2007 11:13 AM
