Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-15-2009, 06:11 AM
flomatic is on a distinguished road
Need Help on Monitor Hang
My CNC MAZAK QT-6T startup normally from the windows software. It runs until the page, where it appears "MAZATROL 640 PC-Fusion-CNC" and it hangs. The monitor hangs at this page. Could someone expert on this machine advice me on the possible causes....?? Please help???
Old 07-15-2009, 10:03 PM
arie2003 is on a distinguished road
I think there is many possibilities,
1. Software problem/corrupt.
Try to reload main A & main B software, PLC ladder, etc.
2. Harddisk problem
Try to change harddisk and reload software.
3. NC hardware problem.
Why you don't call Mazak Singapore to solve this problem? QT6 is Singapore made. I think Mazak Singapore know very well about this machine.
Old 07-15-2009, 10:54 PM
Unhappy Need Help On Monitor Hang
The machine is in china and hence mazak singapore would not help.
Any other ways to help solve?
Old 07-21-2009, 10:05 AM
onthebumper is on a distinguished road
You can try Mitsubishi China at +86-21-6120-0808 or Mitsubishi Singapore at +65-6473-2308.
Some things to check:
The back of the NC control behind the screen should have a "9" and a flashing dot.
I agree with arie2003. You may have a s/w problem. You should be able to reload the Main B software from the hard drive. If you are unsure of how to do this you should contact either Mazak or Mitsubishi. If Main A is the problem then you will need Mazak or Mitsubishi to reinstall because it takes a special cassette.
Old 07-22-2009, 02:32 AM
Change of NC Battery for Mazak System
Can anyone teach my on how to change the battery for the MAZAK QT-6T system? The battery is weak and needs to be change. How to change it, while ensuring the data for the NC system is not lost. Thank you
Old 07-23-2009, 06:52 AM
Unhappy Watch Dog Alarm MAZAK QT-6T
Please help me. My Mazak QT-6T watch dog alarm (WDER LED) light up. Please teach me how to solve this problem. My machine is down. Anyone with knowledge in this, can help pls. Please.....
Old 07-23-2009, 11:15 AM
Did the battery die. If so then the parameters have probably become corrupt. It sounds like you have a Fusion 640 control. If so then change the rotary switch on the back to a 7 and power on. Power off after 10 or 15 seconds at the main breaker. Change the rotary switch back to 0 and power back on. If you get a Mazatrol screen then you will need to reload parameters. Hopefully there is a backup on the hard drive. If not you will need to contact Mazak or maybe someone here has a backup for you.
Old 07-23-2009, 07:42 PM
I have changed the battery. Then i reload the system, the attached screen appear, with the "161/162" error. (Please see attachment for more details). I have not follow your instructions. This is the current situation that i have reached after changing the battery.
Old 07-24-2009, 07:47 AM
It looks like the BIOS may have been messed up or the PC card might be bad. The battery does not back up the BIOS so it sounds strange that it would be messed up. There is a keyboard port on the back of the operation panel. If you plug in a PS2 style keyboard you can press F10 during boot up and get into the BIOS. If you have another machine you can compare the settings. If you cannot do this you may need to order a PC010 from Mitsubishi. It will come with the BIOS pre-installed so you shouldn't have to change the settings on a new card.
Old 07-25-2009, 03:10 AM
Sorry, i cannot locate the PS2 Keyboard port. After Opening the Control Housing, There is a few LED lights on. Attached is 1 picture showing a "-9" digital light. Please assist to show me where the PS2 port is. Another picture is showing the FDD +++. Please help to assist. Thanks very much
ID:	84991   Click image for larger version
  #11   Ban this user!
Old 07-27-2009, 10:59 AM
The unit you have pictured with the -9 is the control. Below that is the keyboard. You will see the hard drive is mounted to the back of the keyboard. Bellow the harddrive you should be able to see the PS2 connection. It is facing sideways.
By looking at your latest post it looks like the control is powering up now though? If so the BIOS should be fine. Is the control still hanging up at the yellow Mazatrol screen? If so it sounds like you either need to reload your Main B software or reinitialize the control. Since you replaced the battery and it was dead I would lean towards reinitializing the control. Once you do you will need to relaod parameters to get the machine to come back up ready.
You can reinitialize by changing the rotary switch on the control next to the -9 to a 7 with power off. Power on for ten seconds then power off to the breaker. Change the rotary switch to a 0 and power on again.
  #12   Ban this user!
Old 07-27-2009, 07:35 PM
Unhappy Mazatrol Screen Hang
Tks for your help. I have managed to locate the keyboard and go into the setup system to re-set the clock. The system managed to load up the win95 software, but hangs at the yellow mazatrol screen. I aborted the software operation and is able to go into the harddisk to see whatever software i have inside the harddisk. I would like to know where to get the Main B software?? How do i load the software? Please help tks.....
Need Help!- Fanuc system 9 loading "hang" waterfall General CNC (Mill and Lathe) Control Software (NC) 0 11-15-2008 08:35 PM
Machine hang during tool change javajesus Sharp CNC 44 01-19-2008 10:27 PM
Want to hang from v2xt v488 Bridgeport and Hardinge Mills 20 04-18-2007 12:21 PM
Side Mount Toolchanger Hang-up pdoherty Haas Mills 4 03-26-2007 01:13 PM
Post help hang up? nervis1 Post Processors for MC 6 01-26-2007 03:20 PM
