Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-15-2009, 03:14 AM
KHOAKHOA20078 is on a distinguished road
Mazak QT 20 spindle's speed divition two
Can you help me? now Iam having a cnc turning machine,it lathe Mazaktrol quickturn 20, sorry i want to exchange with you about my CNC turning machine maner, when I increase the spindle'sspeed is speed only to a haft of the set at parameter, after that it turn back at zero number and go on more increasing but also obitianed a haft of speed of the set at paramet.
Good Luck!
Phuong Lam.
Drill Press Speed Guide, Band Saw Speed Guide zerodegreec General Metal Working Machines 0 02-27-2009 12:12 AM
Need Help!- Mazak QT-10 T2 manuals --acct w/ mazak? CDTINC Mazak, Mitsubishi, Mazatrol 0 06-30-2008 08:42 AM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
CT40 vs. BT40 spindle's and tooling? gunsmither Haas Mills 2 01-08-2007 10:06 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
