Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-12-2009, 11:58 AM
sve0019 is on a distinguished road
Masatrol cam M2
Hello.
Ive have a Mazak VQC 20/40b with Mazatrol cam M2 system.
I have maked a mazatrol program with several units,exept from
the common unit and the fixture unit its have a plane unit and
a line unit and pocket unit and so on.
Please observe it is a mazatrol programme in all, its
not eia/iso.
Then I am running the program i want
the program to jump over some units without deleting them.
These woud be practical in case i will test only a part off
program.
Next time I am runing the cycle i want every units to run
(In EIA/ISO it caled skip block i beleve)
If somebody can help I bee thankfol.
sve0019.
Old 07-14-2009, 11:16 AM
jimiscnc is on a distinguished road
probably impossible
M2 is before my time, but on later mazatrol there is "program copy" in program file.
So you keep one program intact and original and you start out with an exact duplicate.
There is no block skip in mazatrol to this very day.
there is also "unit copy", "figure copy", and "program copy" in later mazatrol versions. Not sure about M2, though.
-90% Jimmy
Old 07-15-2009, 01:26 PM
Abaout Mazatrol m2 and block and units.
Best jimiscnc
Thanks for answer.
Still i like to know if it is possible to skip unit or jump over
a unit.As i say its in mazatrol m2 i am not iso.
Mazatrol has Units,Iso have blocks.
I am asking abaout Units.
Sve0019
Old 07-15-2009, 05:21 PM
iamstink2k is on a distinguished road
i think you can set prioritys to what order you want to run each unit, that was in the m2b mazatrol m2 is similar but not sure if that feature was used in m2 (we have a m2 controler at my shop but, i havent even looked at it much)
Old 07-15-2009, 05:44 PM
daddyjason2004 is on a distinguished road
haven't run m2 in a while, but if i remember correctly there should be a block skip menu tab on your position or command page once you are in auto mode. After u hit block skip, menu changes and asks which number to skip, as the menu tabs are numbered.
Old 07-16-2009, 02:43 AM
Block skip in Mazatrol M-2 Prog.
Best Daddajason 2004.
Your on it its command line in auto mode there i can
press block skip and get a sub menu
with skip block 1.2.3.4.5.6.....
Question is how,i haved try diffr ways without sucess
Is it possible you show how.
Sve0019.
