| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Thanks for any help in advance guys.....the dilemma I have is that I need to shift from the typical Mazatrol programming we normally use on this machine to the EIA-ISO format for a specific job. I use Feature-Cam and have generated my shapes and output NC code. First of all, FeatureCam comes with many post-processors so choosing the correct one may be my issue. I've had no issues sending EIA programs to the Mazak, they just won't fully run. The program below upon Cycle Start will change to the proper tool then just sits there. I just don't know what this machine needs. Are there parameter settings I need to change when shifting from Mazatrol to EIA? Also, is the Z axis the same direction in Mazatrol as it is in EIA/ G-code? Sorry to bombard you guys with all the questions but I'm beginning to exhaust my options. Here's the code I've sent to the Mazak....... O1234 N02G50S1200 T0202M41 G97S1200M3 G0X-2.7Z0.1M8 G96S1200 G04U2. G95G1Z-0.0002F0.015 X-2.5 G3X-1.4Z-0.2746R2.7479 X0.Z-0.4R2.073 G1X0.1737Z-0.3504 G0X-2.7Z0.1312 X-2.557 G96S1600M42 Z0.2464 Z0.1151 Z0.1312 M5 X5.6974Z-8.9707M9 T0200 M01 M30 % Thank you!!!!!!!!!! |
| Can't help you much (don't do much lathes) with a T2 control since I can't remember the last time I saw one but it might be helpful for us is you mentioned what machine model this is on and any other options (sub spindle, live tool, etc). Your spindle probably starts but it won't move beyond that? If I'm thinking right, M41 is a low speed gear select isn't it? Maybe S1200 is out of that range?
__________________ It's just a part..... cutter still goes round and round.... |
| Psychomill....thanks for the reply and YES that M41 does call for low gear. That MAY be it. The spindle does NOT start which is why I think you're correct. I'll try that. Since my post this morning, I've run quite a few different post processors on this program. Alot to try, that's for sure. The machine is a Mazatrol CAM T-2 with no sub spindle or live tool. Thanks again!! Last edited by revlimit; 07-07-2009 at 12:19 PM. |
| Different post processor with the M41 remaining and the program now starts except it tries to return past (it looks like it anyway) home and then gives me a stored stroke error. That's where I am currently....1:15 7-7-09 |
| It looks like the machine is trying to use the home position as X 0, Z 0 and trying to run from there. I'm unsure how to offset these values or what code to insert that allows an offset to be added. Anyone? |
| Native Mazatrol Sample files | CAMFUN | Mazak, Mitsubishi, Mazatrol | 0 | 04-10-2009 02:05 PM |
| need sample program | vintageracer | Milltronics | 3 | 11-15-2008 03:58 PM |
| mazatrol subspindle program sample | Denis13 | Mazak, Mitsubishi, Mazatrol | 5 | 07-30-2008 02:09 PM |
| Need IEI-ISO sample program for Mazatrol 640 T | turkaygeyik | Mazak, Mitsubishi, Mazatrol | 0 | 05-29-2007 09:03 AM |
| I need sample G code program | bunalmis | G-Code Programing | 1 | 08-24-2004 03:50 AM |
