Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-20-2009, 03:11 AM
masi11 is on a distinguished road
Mitsubishi diarol dl-scz
I need help to connect this type of spindle drive.
If you have connection or maintenance manual, please PM me.
Old 07-22-2009, 11:25 PM
Htech is on a distinguished road
Tell me the connections and i will give you the connection locations.
Old 07-23-2009, 11:10 AM
onthebumper is on a distinguished road
You can also go to MEAU.com and download the manual for that drive.
Old 01-18-2010, 03:48 PM
cabbage is on a distinguished road
Yes , I have a Mazak m4 with a fanuc 6TA and a Mitsubishi spindle drive
I have no ready light on the spindle drive ,no alarms ,zero speed light on
it will not enable the hydro pump
it will not enable MDI or Auto (head lube pump not enabled))
but I can force these both on and MDI everything but spindle ,when I manual button push or MDI spindle the spindle pulses in rev. and breaker trips on the mitsubishi drive.
The RELAY inside the controller will not energize
Do you have any Ideas that will help me ?
Old 01-19-2010, 09:18 AM
yes ,it is a Mitsubishi Diarol spindle drive
DIAROL DL-SDZ-2F-30K-A-X-E. camay Mazak, Mitsubishi, Mazatrol 3 07-29-2011 12:19 PM
Problem- Mitsubishi Wire EDM Roswell28 Esprit 1 12-04-2008 10:14 AM
Mitsubishi FX1 Wire one4design EDM Machines 3 10-05-2008 01:37 PM
Mitsubishi M-H5B tturnbull50 General CNC (Mill and Lathe) Control Software (NC) 0 09-29-2008 01:09 PM
CH-VMC 500-Mitsubishi 60S thanhct CNC Machining Centers 5 04-02-2007 02:49 AM
