Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-10-2009, 09:59 AM
epelchat is on a distinguished road
Unhappy Mazatrol Tool Def length Default value
We own a Mazak VTC-200C and just bought a Blum Length Tool Setter. Before auto measurement, we have to manually compute 0 in tool length to avoid tool crash...Murphy made it happen . Is there anybody know how to edit macro to include a command which could automatically compute a zero in Tool length field of tool definition?
Old 06-10-2009, 10:03 AM
psychomill is on a distinguished road
Rather than doing that.... Call Blum and tell them to fix the macro.... They've got something messed up and no reason for it..
Unless this is from some other install... Who installed it?
It's just a part..... cutter still goes round and round....
Old 06-11-2009, 08:48 AM
Length default value Tool setter Blum vs Mazatrol
So far, Blum's technician don't know how to do it with Mazatrol controller and Mazak team didn't propose a solution. That's why I'm asking.
Thanks guys!
Old 06-11-2009, 01:59 PM
Wow... that's the craziest I've heard in awhile...
OK... I think what's hanging it up are machine parameters and the system variables Blum is using to calculate. Several things they need to know....
Is this for Tool setting or Tool break check? Or both?
Are you using Mazatrol Tool Data? or Tool offset page?
Are G43 related parameters pulling from Tool Data? or Offset?
What system variables (if any) is Blum using to read the tool length?
What variables are they using to set the tool length?
What is the motion sequence of the tool setting?
Old 10-14-2010, 12:17 PM
spinboy is on a distinguished road
Question
interesting.....what do you mean you have to zero out the tool data?
If you zero out the tool data you can't check for wear or breakage and that makes no sense at all.
What kind of Blum presetter is this, a laser or mechanical type and when was it installed?
tool length to long laamar Mazak, Mitsubishi, Mazatrol 3 02-13-2009 02:50 PM
Help please - Tool length setup 440regal Fanuc 4 10-07-2008 07:57 AM
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 04:01 AM
Tool Length offset? cncuser1 G-Code Programing 3 08-30-2007 08:59 PM
