Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-26-2009, 02:14 PM
grabolo is on a distinguished road
mitsubishi converter MDS-C1-CV-260
Hallo everybody,I visited this forum very often,found it very usefull,now I need a help.Problem with a mitsub. converter MDS-C1-CV-260.During a big storm we lost a power.Then had a problem-converter is dead.No signal on processor board,no power on the front PC board with processor.Another two amplifiers are running but Mazak shows alarms 204 then 26 probably becouse of dead converter.Mitsubishi asked 3,5k for repaired one.Any suggestion what to do? I,m familiar with electronic stuff but where should I look for a broken element? Thanks.
Old 05-27-2009, 02:03 PM
chippy1 is on a distinguished road
Did you ask Mits how much to repair versus getting a repaired one. If you get the repaired one, do they offer a discount on the defective?
Try disconnecting the fan an see if it works too. Inside and outside if there is two.
Regards,
Chippy
Old 05-27-2009, 03:53 PM
As You see my location is Poland and everything here works a little diffrent.There are two fans the upper one is dead lower is working.I've found a company in Luisville,KY and I'll send it to them to repair.Thanks,
Old 05-27-2009, 04:04 PM
You said the upper fan was not working. Did you disconnect it to see if the CV unit comes up with out it?
I'm curious, what's the name of the company in Louville, KY that will repair it. I may want to use them myself. Is it ASI, but there in Richmond, KY
Regards,
Chippy
Old 05-28-2009, 01:31 AM
MDS-C1-CV-260 repair
Hallo chippy1,today first thing in the morning I'll try to do what You suggest and I'll let know what happening.The company in KY is http://www.ics-repair.com/index.htm their thirst offer was to high but then gave 1k for repair and it gona take about three days,they also got some on stock.Best regards thanks for help.
Old 05-28-2009, 05:22 AM
Sorry this didn't work-the upper fan was broken,I replaced it but nothing changed except the other one is not working too,but is good 100%.It's very difficult to find connections on the pc board as it's multi layer one.
Old 05-28-2009, 08:53 AM
I think you had mentioned there were no LED's on the CV unit. Try disconnecting the buss cable also just to make sure there are no outside shorts bringing down the low voltage power supply within the unit.
Regards,
Chippy
Old 05-28-2009, 09:11 AM
I already tried,nothing changed.I disconected everything except three cables from transformer.The red LED is on,I have 280V DC on bus and no power on processor board,meens no low voltage both fans are dead right now.I changed several elements that I think give voltage for a little transformer but must be something else.Regards , grabolo.
Old 05-28-2009, 09:17 AM
Sounds like you have tried everything. Time to send it for repair.
Regards,
Chippy
eps to dxf converter studysession Autodesk Software (Autocad, Inventor etc) 9 05-25-2009 05:32 AM
Need Help!- DXF converter ParkerMillguy CamWorks 3 12-16-2008 07:09 AM
dxf to dgn converter drafting101 General CAM Discussion 3 10-23-2008 07:51 PM
suitable g- code converter software for Mitsubishi MT Developer? 19darren84 G-Code Programing 0 04-05-2007 09:41 PM
help CAD CAM converter kiethnt General CAM Discussion 2 03-24-2007 09:29 AM
