Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-21-2009, 12:09 PM
turbotech42 is on a distinguished road
Mazak top and bottom turret alignments
I am trying to find out the proper procedure for turret alignments or as some call inclination. I have always removed tools and swept block on x axis toward center line. i would adjust by removing plugs and loosing 8 bolts and use bar to move turret in needed direction. I know the tool nose should on top and bottom turret should be close to touching each other if you bring them together. Also top turret tool nose lines up close to center of the ball on my chuck as well as the tail stock center. The bottom turret tool nose is off center by almost 2mm. All the tool on the bottom check out this way.
I am trying to find a written procedure on how to align top and bottom turrets mazak will not supply this information they want company to pay for training. I have 4 mazaks in my work area and they are used in mass production. Tree of them need alignment on bottom turrets and one needs it on top. Can anyone help me.
Old 05-21-2009, 06:28 PM
bigbobomb is on a distinguished road
why can't you just use a coaxial indicator and sweep the tool pocket that is used for center drilling? mount the indicator in the main spindle and center the pocket to it. that is all i have ever had to do and i have lined up many, many turrets in my 15 years as a mazak service engineer. top or bottom turret are done the same way. it is not that hard to do.
Mazak QT15 turret blocks javajesus Mazak, Mitsubishi, Mazatrol 2 02-09-2008 06:31 PM
Mazak Qt18N Turret Alignment mzartop6 General Metalwork Discussion 0 12-26-2007 08:37 AM
Mazak Nexus 640 Tool Turret problems chattwo Mazak, Mitsubishi, Mazatrol 0 09-21-2007 11:27 AM
Mazak Rotary Turret Switch reBuild Al_The_Man Product Announcements & Manufacturer News 6 04-11-2007 10:21 AM
Look at my bottom Graham S DIY-CNC Router Table Machines 21 12-14-2004 02:12 PM
