Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-12-2009, 01:06 PM
mbpp is on a distinguished road
Sub Spindle Issue on SQT15MS
I just had my machine repaired today and everything seems fine. Everything is working fine in manual mode. The issue I have is with the Sub spindle in manual / Rapid mode it spins fine in both directions at whatever speed i select. The trouble is when I use M303 or M304 (with an S value of anything) in either a program or with the test button it won't move it just seems like it is trying to move, you can't move it by hand it's solid. It seems strange beacuse it spins fine in rapid or manual mode in either direction. M306 and M307 (Chuck open / Close)work fine. Any ideas ?
Old 05-13-2009, 06:25 PM
jimiscnc is on a distinguished road
I'm clueless. Sounds very unusual and may be a by-product of your latest repair?
Does the spindle work in manual jog mode? Opps - you do state it jogs both ways just fine. My bad
-jim
X3 Spindle Issue? chns Benchtop Machines 6 11-26-2008 05:58 PM
How do you like mazak sqt15ms UZU-90 General Metal Working Machines 0 03-29-2008 05:51 PM
fanuc spindle motor issue will_lewis Servo Motors and Drives 4 01-22-2008 06:08 AM
Super X3 Spindle Issue dafowfidy Syil Products 7 01-09-2008 01:17 PM
SQT15MS T-Plus Sub Spindle chips-ahoy Mazak, Mitsubishi, Mazatrol 5 03-30-2007 06:37 AM
