Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-29-2009, 02:10 AM
5xphil is on a distinguished road
Question sub program problem
hello! my english is very bad i am french!
the broblem is...
when i call iso sub program with mazatrol manual program .
ex.( p100. l1. m98)
the sub program dont take the tool compensation G41 G42 .
i have try with manual prog. calling iso program recall iso program and is fail too.
i have try with manual prog. calling mazak prog. recall iso program and is fail too.
i need compensation for the job and i want to call the iso sub prog. with manual prog. for the tool prority.
tanks
Old 04-30-2009, 09:53 PM
psychomill is on a distinguished road
You may not be setting the compensation in the right place. What machine and control is this? Your machine parameters for EIA/ISO comp may be looking somewhere else.
It's just a part..... cutter still goes round and round....
Old 05-02-2009, 07:40 AM
the control is normal 640 m and the iso sub run well when is call withmazak sub pro.
Old 05-04-2009, 09:54 PM
I think we have a bit too much "language barrier" going on here... I'm not sure what you mean by this:
There are some French speaking members on here.. maybe they can chime in?
Problem- Anilam Program Problem JeffreyCNY General CNC (Mill and Lathe) Control Software (NC) 0 04-10-2008 12:30 PM
program problem settingbur CNC Swiss Screw Machines 9 03-21-2008 09:26 PM
Deleting Program Problem Moparmatty Haas Mills 1 03-13-2008 12:08 PM
problem with program and direction woffler Mach Software (ArtSoft software) 7 02-16-2008 07:03 PM
Long Program problem Colin CamSoft Products 12 01-07-2008 04:50 PM
