Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-20-2009, 09:30 AM
yepingapple is on a distinguished road
Red face add u-axis
Hello,
I want to increase U-axis in machine center for cutting tap or circle hole or step.
Can you explain to me how to add an amplfier \ paremeter\ servo paremeter\ motor\PLC and so on ?
The machine is made in Mazak, system is 640M or Matrix.
U-axis tool is made in Komet & Dandrea !
If you have some experience or opinion or have some Mazak machine with U-axis option , please let me know !
Thanks for your kind support !
Old 04-20-2009, 09:56 AM
Al_The_Man's Avatar
It would appear that fairly complete integration has to be done to the CNC controller as it mentions the Komet is controlled by 3 M codes and controls the unit by analogue control with encoder feed back to the controller.
I would contact Komet and ask them exactly what is involved as they mention integration with the Mazak Matrix.
I believe Mazak had some proprietary control over the Mitsubishi 640.
Old 04-20-2009, 06:17 PM
Dear Al,
Thank you !
I appreciate that you will communicate Komet and let know Unreservedly.
Old 04-21-2009, 08:54 AM
Al_The_Man's Avatar
When I said I would contact Komet, I meant that I would would If I were you.
I suggest you contact them by email directly.
Old 04-24-2009, 07:37 AM
I appreciated that you are kind to me !
I heard that if add U-axis, should modify the spindle unit , really?
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
