Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-16-2005, 10:40 AM
SteveCo is on a distinguished road
Unhappy Sending prgrame from EMCO compact 5 cnc to PC
I have a EMCO Compact 5 CNC and I am having problems trying to send data from machine to PC using G-Code 66 as advised. Cables are connected correctly and COMSport is open. Any Ideas? Quite new to this and would appreciate any help you can give me. Cheers - SteveCo.
Old 01-16-2005, 11:35 AM
Rekd's Avatar
Rekd is on a distinguished road
RS232 communications can be one of the most frustrating problems to troubleshoot. There's a lot of things to look for when you're having problems with file transfers.
With that said, make sure the settings on both the controller and the computer match identically. Including BAUD, Stop Bits, Data Bits, Handshaking etc.
After that's all confirmed to be correct, make sure the cable itself is wired correctly and make sure there's no hardware issues. Also make sure that you're using a quality, shielded cable for the transfers.
Try sending a file the other direction. If you're successful here, you've probably just got a wiring or settings or hardware problem. (narrows that down, eh? )
Make sure you're not next to any source of RFI, (Radio Frequency Interference). These sources can come from many places, like welding machines or other high voltage systems, they can come from live conduit, or even come from a (large) live extension cord that's coiled up on the floor.
HTH.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-13-2005, 09:00 PM
toad270 is on a distinguished road
where does the rs232 plug in in the lathe I'm not sure if mine is set-up for it?
if you have any pictures that would be great
another question is how do you figure radius compensation I don't have a clue what the triangle symbol in the book means?
My Emco is the 4th gen.
thanks for the help
Toad270
Old 09-02-2005, 11:52 PM
primotool's Avatar
*Registered User*
primotool is on a distinguished road
does any1 know why i cant end my program w/G-22 code ? I get a A00 error
Old 06-08-2006, 09:09 AM
Motman2k is on a distinguished road
I am Having a problem sending a file to the compact 5 , yet i can receive a file from it??Any Ideas? I have even tried to send the same file that was sent to me so it shouldn't be a data format problem. Anyone help please
Old 07-30-2007, 04:43 PM
bborb is on a distinguished road
Motman2k,
What software are you using on your PC. Some software strips control characters from file headers/leaders, and when you send a program that was recieved from the CNC machine its not exactly the same and the CNC won't accept it.
Emco Compact 5 PC...have ???? Double G Mini Lathe 42 08-22-2010 07:26 PM
EMCO Compact5 CNC help needed. ESjaavik General Metal Working Machines 5 07-15-2005 02:08 PM
EMCO Compact 5 CNC tuning. ESjaavik General Metal Working Machines 7 02-10-2005 11:15 AM
EMCO Compact 5 cnc help Bohdan2 General Metal Working Machines 3 02-06-2004 03:02 PM
Feedback on an Emco ET-420 CNC Lathe Gunner General Metal Working Machines 8 02-03-2004 04:22 PM
