Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-09-2009, 09:19 AM
jdatbmc is on a distinguished road
Cool Mitsubishi control multiple problems
Mitsubishi control on a Mazak VQC 20/40B. After 4 months of power down reinitialized the control but have a few issues.
1) Now shows an "A" axis on screen
2) When doing a tool layout the drum number changes to the program number plus one and all the tools dissapear.
3) On tool data page when cursor is positioned on tool diameter input changes the length.
Old 04-09-2009, 10:31 AM
MrMazak is on a distinguished road
Smile
By reinitialized you mean you followed the Mazak procedure? If you just turned on the machine and it is braindead there is more to it than reloading parameters. Do you have the procedure to reinitialize a braindead M2? (I do, if you need it let me know)After you follow the procedure you will then have to load a parameter backup or put them in from the parameter sheet.
Old 04-09-2009, 10:56 AM
If you mean turning off dip switch #2, turning machine on and off till parity lights go off then returning dip switch back on, that is what I tried. Then reloaded parameters from tape. This machine has a M1 control.
Old 04-09-2009, 11:08 AM
I have attached the Mazak procedure for M2 reinitializing. It should work for M1 also. Good luck with it.
Old 05-28-2009, 08:38 PM
rhurt is on a distinguished road
f2 & f3 keys not powered
I had done the reinitialization with the dip switches and now I cant access the hidden parametes , I can only access the normal parameters and my f2 &f3 keys are not powered (leds dont light up) whats the deal?
Mitsubishi Control problems on a Citizen gearmachinist Mazak, Mitsubishi, Mazatrol 6 01-23-2009 12:06 PM
Mitsubishi Meldas M3 Control? Talisman General Electronics Discussion 19 08-08-2008 07:56 PM
KIA with Mitsubishi 520 Control rikonen Hyundai Kia machine 0 03-28-2008 08:39 AM
Mitsubishi control help needed! rogdog Mazak, Mitsubishi, Mazatrol 12 09-09-2007 01:54 AM
Mitsubishi Control help justin General CNC (Mill and Lathe) Control Software (NC) 2 03-14-2005 06:06 PM
