Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-09-2009, 07:44 AM
CimUser2000 is on a distinguished road
Mazak M32 - G84 Tapping Cycle Broken?
Can somebody give me an example line of code for a typical tapping cycle for a Mazak M32 controller? I'm using the same G-code as an M2 controller (which tapping works perfectly) and here is what happens:
1) Machine spindle starts at programmed speed
2) Machine locates to correct X-Y location
3) Machine rapids in Z to the clearance plane
4) The spindle stops
5) the machine feeds in Z- and smashes the tap
I don't know if something is wrong with the machine or maybe the G84 code is different that the M2 controller G84.
Any help would be appreciated......
Old 04-09-2009, 08:01 AM
Multi-DNC_user is on a distinguished road
Hope this helps.
N1 T05T0M6 (1/4"-20 UNC HSS Straight Fluted)
M01
G92 G40 G80 G90 G17
M3 S1500
G90 G0 X-2.2541 Y-1.2419
G43 Z1.0 M9
G94 G84 G98 Z-0.75 R0.1 F71.25
G80
G91G28 Z0
M99
Old 04-09-2009, 10:02 PM
Thanks...Your code reacts the same way. It looks like the tapping cycle is broken. As a work-around, I will manually program the tapping cycle.
Once I program the full depth of the tap, what is the G-Code for a "pause" command (before I reverse the spindle)? I am using a floating tap holder in the spindle.
Thanks again....
Old 04-09-2009, 10:42 PM
Mazak M32 - Pause Command
I thought I should add some sample code to to clarify what I am after. I want to pause the CNC machine for 1 second after issuing the "spindle off" command before I reverse the spindle and retract Z.....I just need to know what the syntax is to "pause" my program for 1 second (I can adjust it later if needed).
O123
N30G28G91Z0.
N35G28G91X0.Y0.
N40M06T1
N45( T1 - 1/4 TAP )
N55G54G90G00G40
N60G80G17
N65M03S1000
N70G43H1Z2.
N75G00X-2.2541Y-1.2419
N80Z2.
N85Z.1
N90G1Z-1.F71.25
N95M5
N100 "PAUSE" <------------------ Need to pause for 1 second
N105Z.1M4S1000
N110M5
N115 "PAUSE" <------------------ Need to pause for 1 second
N120G0Z2.M3S1000
N125G80
N130M09
N135G00G28Z2.M05
N140G28G91Z0.
N145G28G91X0.Y0.
N150G90
N155M30
Old 04-10-2009, 01:14 PM
MrMazak is on a distinguished road
G94 G04 X1.0
Old 04-10-2009, 01:33 PM
MrMazak.....Is that "G94" supposed to be a "G98" in your reply? I've been browsing the forums and found another person using G98? Although, I have no idea what G94 or G98 do!
Thanks for your reply.....much appreciated!
Old 04-10-2009, 01:35 PM
G94=TIME
G95=Spindle revolutions
Old 04-13-2009, 06:45 AM
cogsman1 is on a distinguished road
G84 is for RIGID tap and you are using a FLOATING holder? Can you say SNAP!
Try using G32 cycle
Old 04-13-2009, 07:48 AM
G84 can be used for both types of tapping (H0=float H1=rigid). G84.2 (3) is always rigid tapping But the bigger question is why use a floating holder? That is likely the cause of all your troubles.
G84 & G74 tapping cycle Karl_T G-Code Programing 8 12-01-2008 07:52 AM
Need Help!- Fanuc 6T-B tapping cycle? party o one Fanuc 5 09-19-2008 11:20 AM
Coolant M7/M8, Tapping Cycle 207 cutteredge General Metal Working Machines 0 01-09-2008 04:12 PM
peck tapping cycle jdsmith0524 General Metal Working Machines 9 12-16-2006 10:36 PM
Correct tapping cycle??? Karl G-Code Programing 5 05-31-2004 04:37 PM
