Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-31-2009, 01:55 PM
uperez is on a distinguished road
thread milling in nexus using mazatrol
Hi guys! I wanted to ask if there's anybody out there who can point me to the right direction on how to thread mill using mazatrol programming.. thanks in advance.
Old 03-31-2009, 02:32 PM
jimiscnc is on a distinguished road
mazatrol thread milling
depends on the control vintage somewhat. you can only do I.D. type thread milling in mazatrol. O.D. would be manual unit or G code.
when setting up a point machining unit, key in "0" (numeric zero) in the field for surface finish designation. the softkeys show 1 through 9 and 0 is not part of the softkey set. this trick FORCES the tool path to always be in helix. if no 0 then mazatrol does a 360 clean up pass at the bottom with no helix! because it thinks youre using a ordinary end mill.
point machining- tap and point machining circle mill can both thread mill, eventually.
its tough to do a blind hole, too, mazatrol starts the mill DEEPER that your Z starting point, to allow ramping in. there may be a tpc that controls this?
i've seen some discussion on fusion and earlier that you have to name the tool as a floating tap? in tool data? matrix its prob best to name the tool as an endmill instead of a tap, too.
this is just my 2 cents. there is probably a few roads to get this. this is just what i remember off the top of my head.
jim
Old 03-31-2009, 03:06 PM
thanks jim! i'll try this first thing tomorrow morning..
mazatrol thread milling cr500 Mazak, Mitsubishi, Mazatrol 7 04-13-2009 08:48 AM
Mazatrol variable thread lead? extanker59 Mazak, Mitsubishi, Mazatrol 0 06-24-2008 01:24 PM
Mazatrol T Plus thread cycle in synch? Castle1 Mazak, Mitsubishi, Mazatrol 2 03-25-2007 10:22 PM
thread milling DavidC1949 G-Code Programing 2 03-30-2006 12:27 PM
Mazatrol Cam T-2 to 640 T Nexus HarleyRyder CNCzone Club House 0 08-26-2005 08:43 PM
