Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-31-2009, 01:25 AM
Legenden is on a distinguished road
Problem with toolchange in Mazak Quickturn nexus II
Hi! I´ve encounterd a problem with the toolchange when using tools with Y-axis offset. For example, we welded two toolholder together, one left and one right, then change the offset in the Y-axis to +25/-25mm and it works great... until the toolchange, the machine goes to overtravel due to the limit in the y-axis when the machine go to the zero return point. Is there a way to work around this???
Old 03-31-2009, 01:39 PM
uperez is on a distinguished road
cancel your offset first and move back to y0 before going to the tool change position.
Old 03-31-2009, 02:36 PM
jimiscnc is on a distinguished road
thats exactly it, uperez!
Turret will not index if Y axis is not home. this requires a manual unit in program with the same tool that brings Y to home before calling the next tool.
matrix has a y axis out of position tolerance parameter for this, but it's not good to exceed maybe .005" or so if you do manage to find it!
jim
Problem- Is this Mazak QuickTurn 10 worth buying? barchdesigns General Metal Working Machines 17 07-14-2009 03:44 PM
Problem programming my Mazak QuickTurn 15 revlimit Mazak, Mitsubishi, Mazatrol 3 10-23-2008 08:28 PM
Newbie- What is the GL/CF button used for on a Quickturn Nexus 300? Y_punishment Mazak, Mitsubishi, Mazatrol 2 06-06-2008 01:23 PM
eia restart problem on mazak nexus 640m mill Denis13 Mazak, Mitsubishi, Mazatrol 1 02-04-2008 08:58 AM
mazak t32-2, quickturn 8n Enda Mazak, Mitsubishi, Mazatrol 3 02-09-2006 04:00 PM
