Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-29-2009, 10:58 AM
carbidecraters's Avatar
carbidecraters is on a distinguished road
Qt15 T32 control...start program little switch sound then nothing
Qt15 T32 control...start program little switch sound then nothing. I dont get any errors it just makes the air selenoid on the side near the spindle end click and it does nothing. Cant run any kind of program! Anyone have a simple fix for this?
We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
Arrow 750 Failed to start when I Push start Bottom in fornt of control ! mte.jalal Cincinnati CNC 4 01-06-2009 10:20 AM
Need Help!- Mazak QT15 with T32-B control does not switch to automatic mode MarkusFunk Mazak, Mitsubishi, Mazatrol 2 06-05-2008 09:54 PM
Start Switch Input to run Mach Setup HELP! PLEASE jimmychand Mach Software (ArtSoft software) 12 12-01-2007 07:05 PM
Unusual problem with program start nervis1 Haas Mills 13 09-01-2007 10:40 PM
Stop/start a program jimglass TurboCNC 3 06-10-2003 08:59 AM
