Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-27-2009, 08:40 AM
mt92 is on a distinguished road
Question Help needed Mazatrol M+ tool hieght
I am running a Mazak with a M+ control in eia/iso. We cannot get it to read the tool height offsets. We have always ran in Mazatrol before. It will run the program above the part but is not compensating for the tool lenght differances.
Could someone maybe post a smple program or expain this to me.
Thanks Mike
Old 03-27-2009, 09:50 AM
MrMazak is on a distinguished road
Smile
Attached is a page describing the parameters you need to check before running g-code.
Old 03-27-2009, 11:28 PM
psychomill is on a distinguished road
you have a G43 in the program?
It's just a part..... cutter still goes round and round....
Old 03-27-2009, 11:43 PM
You don't need the G43 to run Mazatrol Tool Data. I don't know what he wants to use but it's pretty easy to set up either way.
Old 03-28-2009, 10:23 PM
You don't need it if your parameter is set that way... You can still be set to use Tool Data but need G43 and no "H"....
Old 03-31-2009, 03:19 PM
jimiscnc is on a distinguished road
nice write up
that write up i think is still valid to this day.
To summarize, in m/c G code, you can parameterize the tool length comp to do it the G code way or Mazatrol way. Same with CRC.
The G code way is invoked with G43 and H register, same as fanuc. G41/42 and D register, also same as Fanuc.
The Mazak way I think is much much cooler. In mazak land, tool length comp GOES WITH THE TOOL CHANGE. Also, the comp stays in the coordinate system until the tool is changed out. G code reset extinguishes the TLC.
CRC in Mazatrol is invoked with G41/42 and the mazatrol way for crc is that mazatrol programs part shape and mazatrol creates tool path based on ACTUAL DIA in tool data. You can CRC in G code using half the number in tool data, or go straight G code and use the EIA offset registers.
Modern G code program is always to cutter centerline and the CRC comp value is typically small to control size. It's probably best to parameterize to use EIA CRC registers for CRC in G code, as the Mazak way is part shape, and modern G code is cutter centerline.
So you can parameterize the machine for the ways most suitable for your shop and personnel.
I am a big fan of doing TLC the mazatrol way. makes restarts less dangerous.
CRC with a CAM created program is probably best the G code way.
jim
Mazatrol M2 Tool settings help nlh Mazak, Mitsubishi, Mazatrol 3 02-06-2008 02:10 PM
Eia Tool Hieght Offset On Nexus 640 anvil99 Mazak, Mitsubishi, Mazatrol 1 03-22-2007 11:55 PM
Mazatrol tool path abuse MDLang Mazak, Mitsubishi, Mazatrol 1 06-05-2006 05:19 PM
Mazak MTV55/Mazatrol Dead..CPU needed bhagwan General Metal Working Machines 1 10-18-2004 01:01 AM
