Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-27-2009, 07:16 AM
nnpepe is on a distinguished road
Question Mitsubishi DL MAZ Spindle Drive
Looking for a replacement DC Spindle Drive for a Mitsubishi Meldas 500L series DL-MAZ with the following ratings:
Type: DL-MAZ
INPUT: 3 Phase 200V @ 50 Hz; 220/240 VAC @ 60Hz.
Single Phase Control Circuit @ same voltage as above
OUTPUT: 0-210 VDC @ 215A Max
Field: 65VDC @ 20A max
Doesn't have to be a DL-Maz, doesn't even have to be Mitsubishi (I'm an integrator and can pretty much adapt anything that's even close)
If it helps motor specs are as follows:
DC Super Line 30KW 210VDC @ 165A
Model: Type: SDN-CFZ
S/N: Z11783001
Drive that is in my customer's machine at present will either cause Forward and Reverse Motor contactors to chatter or will just simply stop the firing circuits to the SCR's (uncontrolled stop). Don't really relish the thought of rebuilding this unit (although it is an alternative). Customer has already spent a ton of money on different repair approaches. Any help would be greatly appreciated.
Old 03-27-2009, 03:59 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
This is a pretty old drive. I would suggest replacing it with either a Eurotherm or a Control Techniques (Quantum) drive. Both of these drives are pretty easy to integrate to these old DC motors.
Thanks,
Scott
Old 03-27-2009, 04:30 PM
Thanks Scott, I will look into that.
Regards;
Norm
Problem- Mitsubishi FR-SGJ Spindle Drive mikwest Mazak, Mitsubishi, Mazatrol 8 04-29-2010 04:03 PM
Need Help!- MITSUBISHI SPINDLE DRIVE UNIT MDS-A-SPJ-75 chagin General Metalwork Discussion 0 08-09-2008 12:19 AM
Mitsubishi MDS spdl. drive parametrization. GPena Mazak, Mitsubishi, Mazatrol 3 12-19-2007 02:36 PM
mitsubishi spindle servo drive intermax Servo Motors and Drives 1 11-03-2006 09:15 AM
mazak mitsubishi spindle drive intermax Mazak, Mitsubishi, Mazatrol 0 11-03-2006 07:56 AM
