| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
hi, am try to run the ISO programme in mazatrol m32B control with 4th axis. before lot of ISO programmes run i don't had any problem but now i got a error messg address code error. i thoroughly checked there is no mistake and i load the progamme to another control its working. i don't know were is the mistake? if anybody knows pls assist. thanks, sridhar |
| Sridhar, You need to put the code in your message, regardless if it is works on another machine or not. We need to see the programming that you have used to help understand the problem. When did this problem start also? When was the last time you ran this program? Was someone else running this machine? Did you loose parameters on this machine? We need to understand what led up to this event. Such as; it was running yesterday, and today when you came to work, it doesn't work any more. Regards, Chippy |
| Tape Drip feed on Meldas50 - P32 Address Error | firechcken | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 05-26-2008 09:16 AM |
| ps 101 error code help! | AC_Engineering | Bridgeport and Hardinge Mills | 2 | 11-13-2007 06:01 AM |
| Error code in SprutCAM? | MichaelHenry | SprutCAM | 4 | 06-25-2007 07:24 AM |
| art code error | Mike Boarman | Mach Software (ArtSoft software) | 4 | 12-30-2006 10:46 PM |
| M01 error code | MRU | Mazak, Mitsubishi, Mazatrol | 2 | 06-12-2006 07:59 AM |
