Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-23-2009, 08:15 PM
CimUser2000 is on a distinguished road
Drip feed mode for Mazak M32
Does anybody use the Mazak M32 controller in "drip feed" mode? There is not much memory in the controller and we are using a cam system to produce G-code. I can successfully send "small" files into the memory of the controller to run them using the Tape I/O softkey. If I use the DNC option, it error's out with "DNC option not installed". Is there an optional board that has to be purchased from Mazak?
Old 03-24-2009, 08:12 AM
MrMazak is on a distinguished road
Smile
All you need to do is put the control in "Tape" mode. (the key next to Memory) At that point the Work number in the upper right of the screen turns to asterisks and the control will wait for data to start coming from the RS232 port. First hit "Cycle Start" on the control then send on your computer and the M32 will take what it can and start running. When it needs more code it will call for it. Set your software to "wait for CNC". When the control sees the M30 it will stop asking for code.
Old 03-25-2009, 12:01 PM
bughead118 is on a distinguished road
Mazak M32 comms
Can you supply the cable details and pc protocol required to communicate with an M32 control as I'm having problems just sending ISO programs in and out, thats before I get onto drip feeding, thanks
Old 03-25-2009, 01:08 PM
MrMazak.....Thank you so much...It worked like a charm! The Mazak manual does not explain this.
Old 06-03-2010, 04:38 PM
alejorestrepo85 is on a distinguished road
I have a vqc-15/40, m32. I also want to drip feed. what software are you using?
Old 07-11-2010, 07:55 PM
Using "Multi-DNC" software
Need Help!- Drip feed mode with Fanuc OMA visu Fanuc 3 08-14-2008 12:00 PM
Mazak eia drip feed help mt92 Mazak, Mitsubishi, Mazatrol 0 07-16-2008 07:24 AM
Drip feed? kotten1 Mazak, Mitsubishi, Mazatrol 5 07-08-2008 02:44 AM
DYNA 2400 drip mode JimHs Benchtop Machines 6 01-31-2008 12:53 PM
Drip feed mode for FANUC-6M Digitech Machine Problems, Solutions , Wireless DNC, serial port 3 01-29-2008 04:19 AM
