Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-19-2009, 05:23 AM
camtd is on a distinguished road
MELDAS 520 M CONTROL
What is the fastest baud rate the MELDAS 520 M CONTROL year 2000 is this control capable of?
Old 03-19-2009, 05:25 AM
I forgot to add is the MELDAS 520 M CONTROL a good control for doing high quality 3d machining?
Thank You
Old 03-19-2009, 08:45 AM
CNC Viking's Avatar
CNC Viking is on a distinguished road
camtd,
Which machine make, model and year is your Meldas 520 installed in? The machine builders use to have different approaches.
If you set parameter #2, Baudrate to 0, you have 19200 Baud.
It dripfeeds and moves quite nicely while running a 900 kB 3-axis test program in TAPE mode. When you dripfeed it the program size cabability is infinite though.
The control itself is capable to run 4-axis. You just have to add the 4th axis hardware and enable it in the parameters.
I have a lot of settings, cable pinouts etc. Send me a PM or find info in my previous posts.
I even dripfeed over LAN (Ethernet) and a SDS= Serial Device Server. 100m distance from PC-to-CNC=No problem!
/Peter
Old 03-19-2009, 09:14 AM
peterpan3's Avatar
peterpan3 is on a distinguished road
I find if I go over 30 imp in my machine (Supermax) I start losing detail of the contour.
Mitsubishi Meldas M3 control Talisman Mazak, Mitsubishi, Mazatrol 18 12-21-2011 10:46 PM
DynaMyte 4400M with Meldas M3 control bkobernus Mazak, Mitsubishi, Mazatrol 15 12-24-2008 07:42 AM
DNC Meldas MO control? cut more Mazak, Mitsubishi, Mazatrol 3 08-15-2008 07:03 AM
Mitsubishi Meldas M3 Control? Talisman General Electronics Discussion 19 08-08-2008 07:56 PM
Meldas 64 control card slot ?? ajm100a Mazak, Mitsubishi, Mazatrol 0 04-27-2008 04:17 AM
