Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-12-2009, 05:40 AM
Jcip's Avatar
Jcip is on a distinguished road
Ridgid Tap on VTC-41 ?
Setting Rigid tap for for MX-2 controller the book has very little info on this. So how do you know you even have it? I know it's an option but an important feature like this, you would think they would have a little more info on this. What I get from other posts is the "H" value on the same line as G84
G84 X Y R Z P H(?) Does this look right
any tips would be appreicated
Jim C
Old 05-20-2009, 07:20 PM
maz43's Avatar
maz43 is on a distinguished road
Tapping
I just started working with a '94 Mazak 41M with Yasnac control.
Rigid tap for it uses the following format-
G93
G84Z R F
G94
G93- RIGID TAP ON (MODAL)
G84Z (DEPTH) R (REFERENCE PLANE) F (LEAD= 1/PITCH)
G94 CANCEL RIGID TAP (MODAL)
Old 05-20-2009, 09:31 PM
psychomill is on a distinguished road
The above should be right as I recall ... should follow the standard Yasnac format.
The "H" you're referring to started on the Mitsubishi built controllers. The "H" can control the type of tapping cycle and switch between synchronous or floating with a "H1" or "H0"...
It's just a part..... cutter still goes round and round....
TM-3P more ridgid than TM-1P? juxtoposed Haas Mills 1 06-09-2008 12:46 PM
peck ridgid tap/2 fuzzyracing1967 Haas Mills 10 03-15-2008 03:55 PM
Ridgid Tapping on Haas Shotout Haas Mills 14 08-01-2006 09:40 PM
going to try it ridgid dgalaxy Mechanical Calculations/Engineering Design 0 06-11-2006 03:56 PM
ridgid tapping with servos miljnor Servo Motors and Drives 10 09-21-2005 01:35 PM
