Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-07-2009, 04:51 PM
DANMI38 is on a distinguished road
Red face MELDAS 300 series
help me with my problems I can not make a cnc machining box because it does not recognize codes g2 and g3 mark mistake P70 oh if pain is the programming manual for MELDAS 300 series I can pass on that page or download it
Old 03-09-2009, 04:51 AM
perfect is on a distinguished road
I am also having Meldas 300 series controller.
I am having booting problem.
The machine is LeadWell TDC 450
i need backup of parameter.
may be once my machine boots then I could have solution to your problem.
thanks
Old 03-09-2009, 10:59 AM
know very little control over this because I am just getting to know and I do not have the correct manual meldas 300 series
but like you step back in as soon as I get downloaded from the machine
my problem that the machine will not do the function G2 and G3 and try using example ...N43 Y14.285
N44 X-19.285
N45 Y13.571
""N46 G2 X-18.376 Y14.285 I7.065 J-8.056 """
N47 G1 Y16.825
N48 X-21.825
Need Help!- How to initial parameter error meldas 300 series gunawan_tehnik Mazak, Mitsubishi, Mazatrol 5 03-24-2012 05:07 AM
Need Help!- problems while booting MELDAS 300 series CNC LEADWELL TDC 450. perfect Mazak, Mitsubishi, Mazatrol 3 02-09-2012 03:16 PM
Need Help!- Meldas-300 series / MNAP L III initialize procedure iNUC Mazak, Mitsubishi, Mazatrol 10 04-22-2010 05:16 PM
How to change to Baudrate on Meldas 300 Series Controller? Josh Lehman Mazak, Mitsubishi, Mazatrol 1 01-16-2009 04:20 PM
meldas 50 Series nastek Mazak, Mitsubishi, Mazatrol 5 12-31-2006 09:32 PM
