Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-04-2009, 01:19 PM
drlx3 is on a distinguished road
Question AJV 15/40 M2
Good afternoon
This is my first time posting on here, So I'm not that familar with this.
I've got a ajv 15/40 with a m2 control. The problem that I'm having is drilling a .037 dia. hole .125 deep. Simple enough but it wants to start .2 above zero
and begin there. There's 50 holes in each part, taking way to long. I'm sure this is controlled by a parameter but can't figure out which one. Any help would be appreciated. Thanks drlx3
Old 03-04-2009, 10:32 PM
psychomill is on a distinguished road
Are you running G code? Machine should only do what you tell it so it's likely to be in the code.... can you post it?
It's just a part..... cutter still goes round and round....
Old 03-05-2009, 11:29 AM
no I'm using mazatrol.
Old 03-05-2009, 02:02 PM
Hmm... M2 control, ... I can't hardly remember it. Been a long time since I've seen one. I know on the generation after yours, you can control in TPC but I don't remember for M2. There are some M2 users on here... maybe they'll chime in.
Old 03-06-2009, 01:37 PM
MrMazak is on a distinguished road
Wink
BS2 is the parameter for R plane on M2. This only can be set in .1 increments and cannot be set to 0. So the setting is 2 on your machine hence the .2 clearance plane. Parameter INZ will be used for R plane if the following conditions are met. (INZ can be set in .01 increments) Parameter BTD bit six must be set to 1 (add 64 to the number already there) and if preceding the drill a center drill is used in the unit. If no center drill BS2 is used. So adding a spot drill and blasting it at high feed and speed say .01 deep will allow the following drill to use INZ to shorten your drilling air cut time.
Old 03-09-2009, 10:32 AM
Talking
I want to think mrmazak for your help. I appreciate your help, we are up and rolling. drlx3
