Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-28-2009, 07:07 AM
ronsizer is on a distinguished road
Question MDI Question
I am skimming the top of a 5 x 14 square pc. of C715. Instead of jogging it and holding that button, I wrote a little program in MDI and tried to run it. I set my G54 and tool length offset but it didn't read Z on my G43 line and crashed. Luckily my G54 was working and the X and Y moved the pc. out of the way of the crashing tool. My question is did I miss something when I set my Z or can I run a program in MDI ?
Old 02-28-2009, 10:05 AM
psychomill is on a distinguished road
Post your code... G43 should still work in MDI.
Another thought though.... did you have a tool length set in your offset or tool data? and you called the right H number? (just questions... sometimes we do an 'oops')
It's just a part..... cutter still goes round and round....
Old 02-28-2009, 10:13 AM
Eurisko is on a distinguished road
You should be able to do this in MDI. Make sure that the work offset (G54) is set properly in X, Y & Z. Also make sure that G54 is active.
I don't normally use MDI for multiple lines of code. It's much safer to create a small program in Edit mode. You could also copy and modify an existing program. Easier to debug.
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
