Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-26-2009, 05:59 AM
chuckb is on a distinguished road
Program using Mitsubishi Controls
I will be working with Mitsubishi controllers and have previously worked with only Fanuc. Could someone please post an example of a program, written on a Mitsubishi controller (drilling, tapping and interploating) Any place to find G codes or any cheat sheets would be hepful. THANKYOU
Old 02-26-2009, 08:37 AM
chippy1 is on a distinguished road
Go to meau.com and select Downloads. From there click on manuals. It will then prompt you to select a product line such as computer numerical controls. This is a drop down box. Then select CNC on the next drop down box. If you know the CNC model pick it in the next drop down box. You should be able to get a programming manual. The Mits programming is similiar to Fanuc in G-Code. Actually almost exact. Mits also has a method to choose two different programming models. Some controls use and L for the programming mode where others use a O for the programming mode.
Regards,
Chippy
Old 02-26-2009, 10:19 AM
Hi
Thank you so much for your replay Chippy.
I really appreciate it, that's the type of info I was looking for
program input/output with RS232 port on Mitsubishi 50L Chuck Reamer Mazak, Mitsubishi, Mazatrol 3 02-04-2008 02:56 PM
Jog Controls dafowfidy Mach Mill 2 03-21-2007 04:01 PM
Controls Chuck Pool General CNC (Mill and Lathe) Control Software (NC) 7 02-23-2006 11:49 AM
Medelas Mo controls justin Mazak, Mitsubishi, Mazatrol 17 01-17-2006 06:46 AM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
