Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-20-2009, 05:17 PM
jaques4life is on a distinguished road
Mirror image on Mazatrol M32B???
I have a Mazak mill with a Mazatrol M32B control. I am trying to mirror image a program from the control??? Is this possible? If so please explain how. Thanks for any help.
Old 02-21-2009, 12:42 AM
psychomill is on a distinguished road
I can't remember if it was an option on the 32 controls or not... I think it should be G51.1/G50.1 for on/off. I'd have to check ....
It's just a part..... cutter still goes round and round....
Old 04-06-2009, 10:14 PM
mbi mbi is offline
mbi is on a distinguished road
I don't like useing mirrio Image. If you must reset in the middle of running a program the Mazatrol will nor reread the Mirror Image. G50.1 Programmable mirror image cancel
G51.1 Programmable mirror image
Old 04-07-2009, 02:52 PM
MrMazak is on a distinguished road
Mazatrol or EIA?
Old 04-07-2009, 10:04 PM
mbi mbi is offline
Mirror Image
M-90 cancle symetrical image valid (MAZATROL)
M-91 wpc x valid symetrical image valid (MAZATROL)
M-92 wpc y valid symetrical image valid (MAZATROL)
M-93 wpc 4 valid symetrical image valid (MAZATROL)
Place a M code unit in front of the unit or program you want to image and then palce a M code unit after the unit to cancle it.
Caution you can not reset in the middle of a Mazatrol program and than restart.
You must start from the beginning.
Old 04-07-2009, 10:23 PM
Smile Restart mirror image
FYI...Restart is possible by having a M-Code Unit with the M91,92 etc in it. Put a priority one number before the tool you want to restart on then restart from the M-Code unit. I usually have a "restart m-code unit with delay 99 in it and change the priority if the need to restart arises.
Old 02-02-2012, 11:38 AM
harshal_hivarka is on a distinguished road
[QUOTE]
INSTEAD OF USING M CODE UNIT, YOU CAN INSERT CODE AT TOOL LINE WHERE YOU CAN DIRECTLY INSERT M91 AFTER CUTTING SPEED & FEED.THEN YOU CAN RESTART PROGRAM FROM ANY UNIT.
mirror image cp465vw Machines running Mach Software 8 04-13-2009 10:39 PM
Need Help!- Mirror image rbach Mach Mill 0 01-19-2009 11:58 PM
MIRROR IMAGE HELP TOM R CNC Machining Centers 1 12-01-2008 02:01 PM
Need Help!- Mazatrol M32B DNC option chippah Mazak, Mitsubishi, Mazatrol 4 02-01-2008 02:57 PM
Mazatrol M32B and EMC2 iwebcodms LinuxCNC (formerly EMC2) 1 11-15-2007 08:09 PM
