Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-11-2009, 05:44 PM
reillyeng is on a distinguished road
Mazak T32-3 Alarm 015 System Malfunction
Hi guys,
I've got a Mazak SQT15MS T32-3. When I turned it on today the keys at the operation panel were not working and a few minutes later Alarm 15 "System Malfunction" came up on screen. I restarted several times but the same result. I looked in the electrical cabinet and when it's started initially all the drives LED's appear correct (i.e.: X/B Drive :Flashes between d1 & d4 . Z Drive:d2. Sub Spindle Drive: r0 . Main spindle Drive r0.) but after a few minutes the main spindle drive LEDs go blank, showing nothing (that's when the Alarm comes up on screen).
In the Alarm manual it says the following :
Alarm 015 System Malfunction.
Cause: An error occurred in data transmission between MCP and the Amp when the power is turned on.
Action: Check Amplifier for :
Improper connections.
Improper power connections.
So what I'm wondering is what is the MCP and what Amp are they on about ?
Any advice please ? Is this a sign of some problem anyone is familiar with ? What's my best course of action ?
Old 02-15-2010, 11:10 AM
gearmachinist is on a distinguished road
I've run into a similar problem. If you don't mind me asking, what did it take to get your machine back up and running?
Thank you,
Gary
Old 02-15-2010, 11:54 AM
girishdk is on a distinguished road
Need Help! Mazak T32-3 Alarm 015 System Malfunction
Is the spindle drive FR-SF? If so, check the Yellow LED on the SF-PW (power supply) on top side of the Spindle Drive.
If it is off, there are several reasons,
1) Any of feedback cables grounded.
2) Faulty SF-PW.
3) Faulty SF-CA card.
Regards,
Girish
Old 02-15-2010, 12:17 PM
The drive is a FR-SF and a yellow and green led are lit at the top of the drive. The drive gives an AL 36 alarm with is listed as a Transfer Error.
Thank you for your help,
Gary
Old 02-15-2010, 11:35 PM
Thumbs up Need Help! Mazak T32-3 Alarm 015 System Malfunction
Problem could be the CAM11 cable or the MCP/CPU (MC1xxx) card on CNC from which this cable comes out.
If CAM11 cable is ok, need to check
1) Memory clear & reload from backup
2) Replace MCP/CPU card & check.
May be MELDAS service engineer required for this.
Regards,
Girish
Old 02-16-2010, 05:22 AM
I really do appreciate you taking time to respond and the information you provided. We will check these items out and will probably have to call Mitsubishi.
Thank you,
Gary
Old 02-17-2010, 06:49 PM
Rokkin is on a distinguished road
If the LED's go out after a few minutes with the machine just sitting idle, it sounds like it's just a weak SF-PW.
Old 05-26-2011, 03:15 PM
TechnoCNC is on a distinguished road
Mazatrol 640t 15 system malfunction
Hello There
We do have the same error on Mazatrol 640t 15 system malfunction so i was wondering did you got your machine working back to normal.
On our machine it started with RTC battery error and will not boot to win95 so replaced the battery then did boot but at last it stuck on this error all though the all functions works eg spindle spins, tool changing but can not get reed of this error.
Please do let me know if you do got your sorted.
Thank you
Old 05-27-2011, 08:24 AM
Hello There
I have the same error as you had (15 system malfunction) is your machine is up and running if so could you please let me know what you have done to get reed of that error.
Look forward to hear from you.
Thank you
Raj
Mazak H-500 Alarm newguy81 Mazak, Mitsubishi, Mazatrol 4 09-27-2007 09:33 PM
PMC system alarm dalvinder Machine Problems, Solutions , Wireless DNC, serial port 4 09-05-2007 08:28 PM
Mazak VTC-160 A servo malfunction sting_dot Mazak, Mitsubishi, Mazatrol 3 05-21-2007 11:19 PM
System Alarm # 3 tedh General CNC (Mill and Lathe) Control Software (NC) 6 07-25-2005 05:12 PM
Mazak L Alarm SFA Machine Problems, Solutions , Wireless DNC, serial port 2 05-26-2005 12:52 AM
