| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
We have a lathe with M32 control and we had a crush I need to adjust the tool setter When I measure the tool and cut with this tool I have Difference of 0.21mm between the part that I check and What I got on the screen did someone know how to adjust it |
First off, do you have a lathe or a mill. You said lathe, but you also said M32. The M in M32 is for mill, otherwise it is a T32, T for Turning. If you guys had a crash, did you fix whatever moved in the crash. If so, then the easiest fix is to use tooleye comp in the tool data. For a more permanent fix you will have to adjust the parameters that control the position of the tooleye. If this is a lathe, are the od's big, and the id's also big? have you pulled taper on the headstock to verify that the spindle is still inline with the z-axis ways? Many more questions? Mikiemo |
| Need Help!- Tool Setter Macro for M-V60C and Metrol Setter | mitshack | Mazak, Mitsubishi, Mazatrol | 0 | 10-06-2008 08:39 AM |
| Need Help!- Tool setter macro for M-V60C and Metrol setter | mitshack | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-06-2008 08:38 AM |
| TOOL SETTER WITH G50??? | DublJ | Fanuc | 0 | 07-30-2008 07:28 AM |
| Tool Setter | GARY DAVIS | Fadal | 6 | 03-18-2008 07:44 PM |
| tool setter | ACME | General Metalwork Discussion | 8 | 07-30-2005 11:15 AM |
