Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-26-2009, 04:32 PM
pa2262 is on a distinguished road
Mazak T2 alarm codes
Hi All,
I recently acquired a late 80's QT-15 with the CAM T-2 control.
I was wondering if there exists a listing with explanation for the various alarm codes that may crop up?
I have a persistent alarm every time I try to run a sample program.
When I hit cycle start,the number 293 pops up,and a LED lights next to something called "MC" alarm.This particular alarm has no explanation in the manuals that came with my machine,which total two books.One is an operating manual,and one is a programming manual.
Unfortunately these seem to be for a QT8 and not a 15.
The dealer I bought the unit from indicated the info should be virtually the same.
At this point,that is hard to tell for sure.
I figured I'd get on here and ask before I get involved with MAZAK corporate HQ.
BTW,I can get the machine to move manually by way of the various controls,so maybe I am just missing something in my setup and/or program???
I appreciate any tips you care to throw my way.
Craig
Old 01-27-2009, 03:55 PM
chippy1 is on a distinguished road
Take a look on your diagnostic screen and see if there is more information to that particuliar alarm. I think you maybe just looking at the alarm at the bottom of the position page.
My book says something about the tail stock or tail spindle. Maybe you are in an interference position.
Regards,
Chippy
Old 01-28-2009, 07:53 AM
CHANDRU is on a distinguished road
MAY BE THIS CAN HELP YOU
Hei Friend,
Just check whether you have given any magazine cover close command in your programme, also check whether the tool merasuring unit is obstructing your tool / axis movement. After the tool measuring unit is used it should be made to close.
CHANDRU
Mazak H-500 Alarm newguy81 Mazak, Mitsubishi, Mazatrol 4 09-27-2007 09:33 PM
Mazak FAN alarm leito1489 Mazak, Mitsubishi, Mazatrol 2 09-08-2007 08:22 PM
Mazak SQT 100MS Extended M-CODES thewiz90 Mazak, Mitsubishi, Mazatrol 4 05-12-2007 03:56 PM
Mazak alarm code 323. Need help please. RMagnusson Mazak, Mitsubishi, Mazatrol 8 02-20-2006 03:05 PM
Mazak L Alarm SFA Machine Problems, Solutions , Wireless DNC, serial port 2 05-26-2005 12:52 AM
